width45%
The Raw Refraction Filter Color Channel is Channel is similar to the Refraction Filter Color Channel, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of refraction.
width5%
width50%
Image Removed
UI Text Box
typenote
 To properly calculate the Raw Refraction Filter Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Path
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel >
 V-Ray Color Channel (RE) > Type > Raw Refraction Filter
width5%
width50%
Image Added
Usage Examples
The Raw Refraction Filter Color Channel is useful when a precise mask is needed for refractive objects. Unlike the Refraction Filter Color Channel, there is no need to clip or readjust values when pure black or white is required for the composite.
