The example shown here shows the shader ball with a reflective material lit by an environment light with a V-Ray Softbox Texture applied.
UI Paths
width | 33% |
||mat Network||
> V-Ray
> Texture: Procedural
> V-Ray Softbox
width | 33% |
||out Network|| > V-Ray Render Elements node > V-Ray
> Texture: Procedural
> V-
Ray Softbox
Section | ||||
Section | |||
Node
Radial Vignette
Vertical Vignette
Horizontal Vignette
Frame Vignette
Spots
Color Tweaks
Alpha Tweaks
Placement
UV Noise
Gradients
The Gradients options allow the user to blend gradient textures on top of the V-Ray Softbox texture. You can add a gradient in the U and V direction and place a frame - which is a gradient in both directions.
