The most common workflow for the Surface Luminance node attributes is to connect the node to a floating texture input slot of an V-Ray ExtraTex render element. This way you can control the Luminance mode showing in the ExtraTex channel.
UI Paths
width | 33% |
||mat Network|| > V-Ray> Texture: Procedural > V-Ray Surface Luminance
width | 33% |
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Procedural > V-Ray Surface Luminance
width | 33% |
Node
Section | |||||||||||||||
