V-Ray for Houdini offers several mapping nodes. They are used together with textures inside the Mat Network to specify how to interpret UV coordinates on the mesh.
UI Path
||mat Network|| > V-Ray > Texture: Mapping
33%
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Mapping
column
width
Image Added
33%
UI Expand
titleUI Path: ||mat Network|| > V-Ray > Texture: Mapping
width33%
width
Image Removed
Mapping Types
Fancy Bullets
typecircle
Additionally, the Environment Settings node (Env Settings) can be created from the Mapping category.
