width62%
The V-Ray Toon Render Element renders the entire scene with the  V-Ray Toon rendering effect and contains a mask for the toon outlines, although the toon color is not present in it. It also supports opacity set from the toon effect, presenting it as grayed outlines.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Toon
Multiexcerpt include
MultiExcerptNameRE
PageWithExcerptRender Elements
Image Removed
width5%
width33%
