width62%
The Sheen Reflection Render element is analogous to the Reflection Render Element with the main difference being that all Sheen render elements can be subtracted from the main back-to-beauty composite, graded, and added back in Reflection Render Element.
The Sheen Reflection Render Element stores the indirect reflection information calculated from the materials' reflection values in the scene VRayMtl Sheen Layer. Surfaces with no reflection Sheen values set in their materials will contain no information in the render pass and will therefore render as black.
The Sheen Reflection Render Element is formed by multiplying the Raw Sheen Reflection Render Element by the Sheen Filter Render Element . So while the raw sheen reflection pass gives the full reflection of objects reflecting in the scene, the sheen reflection filter sets how much of that reflection should come through in the composite. The two are multiplied together to create the Sheen Reflection pass which gives a true representation of the reflection in the scene.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Sheen Reflection
Multiexcerpt include
MultiExcerptNameRE
PageWithExcerptRender Elements
width5%
width33%
