Material ID Color render element creates a mask based on the material ID Color parameter. To add the render element, you first need to add Material ID attribute from the Add Attribute button () to the material.
Opacity color and textures are supported by the Material ID Color channel.
This render channel is useful in a compositing process as a color mask for different materials in the scene.
width
5%
width
50%35%
Before after
afterLabel
Material_ID_Color
dark
true
beforeLabel
RGB
Panel
borderStyle
none
Panel
borderStyle
none
How to Set Material ID Color
width
35%60%
After you add a Material ID attribute to the material, an automatic Material ID Color is set, but you can change it from the Asset Editor and select the preferred ID Color.
