The Light Select Render Element represents the lighting contribution from a list of one or more user-selected lights in the scene. Each Light Select channel can output one of the predetermined contribution types like the overall direct or indirect illumination or the direct or indirect diffuse or specular contribution to the illumination. The Full mode essentially creates a Beauty render for just the included light(s). The Light Path Expression mode allows for custom contributions to be captured. See the Light Path Expressions page for more information.
Multiple Light Select outputs . It can output their direct contribution (in Raw, Diffuse, Specular or normal Illumination mode) or their Full effect on the scene illumination (including GI, SSS, reflection, refraction, etc). Multiple Light Select elements can be rendered for a single scene, and lights may be included in more than one Light Select render element. However, a good practice is to have one
By using the Light Select element for each light source in your scene. This wayrender element, specific lights in the result resulting render can be captured and adjusted (color, temperature, brightness, etc.) , while compositing in a composite without the need of to re-render. For example, by generating a Light Select element for all of the backlights in a scene, an artist may adjust the backlighting of the rendered scene easily in the composite, without affecting the rest of the scene's illumination.
Section | |||||||||||||||
Lights List
