This page provides information about the Hair material in V-Ray for SketchUp.
Section | |||||||||||||||
UI Options
Diffuse
Primary Specular
Secondary Specular
Transmission
Anchor | ||||
Example: Transmission Glossiness Length and Width Parameters
This example shows the effect of the Transmission Glossiness Length and the Transmission Glossiness Width parameters. It shows a number of vertical strands (in this case, produced by VRayFur) lit from behind by a spherical light.
Note how each parameter changes the way light scatters along the length and the width of the strands. Higher values for the length glossiness compress the transmission highlight along the strand length, while lower values expand it.
Section | |||||||||||||||||||||||||||||||||||||
Options
Multipliers
Binding
Override Control
Can be Overriden – When enabled, the material can be overridden when you enable the override color option in the Global Switches.
Attributes
The attributes from the following expandable menus are available for the Hair material.
Anchor | ||||
Expand | |||||||||||||||||
Raytrace Properties
Expand | ||||||||||||||||||||||
Material ID
