This is a command-line utility that can be used to convert .vrimg image files to .exr files in OpenEXR format. Find out more: V-Ray Image to EXR Converter
width
5%
width
20%
UI Text Box
size
medium
Denoiser Tool
The Denoiser Tool is a command-line utility that can be used to denoise still images or animations outside of SketchUp.Find out more: Denoiser Tool
width
5%
width
20%
UI Text Box
size
medium
Plugininfo Tool
A command-line utility that lists V-Ray plugins and detailed description for them. Find out more: Plugininfo Tool
width
5%
width
20%
UI Text Box
size
medium
Filter Generator Tool
The Filter Generator is a simple tool for composing filters (HDR images in *.hdr format). It is specially designed to produce filters for theLens Effects. Find out more:Filter Generator Tool
width
5%
width
20%
width
5%
width
20%
width
5%
width
20%
width
5%
GI Tools and Utilities
width
20%
UI Text Box
size
medium
Irradiance Map Viewer
The irradiance map viewer can be used to view, merge and save irradiance map files created by V-Ray.Find out more:Irradiance Map Viewer
