width20%
UI Text Box
sizemedium
V-Ray Standalone Command-Line Options
The V-Ray Standalone tool is a command-line rendering tool supporting V-Ray's native .vrscene file format.
Location (Windows): Start Menu\Programs\Chaos Group\V-Ray for SketchUpRhino\V-Ray standalone command prompt
Location (Mac OS): /Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUpRhino/extension/vrayappsdk/bin/vray.bin
Find out more:  V-Ray Standalone Command-Line Options
width5%
width20%
UI Text Box
sizemedium
V-Ray Image to EXR Converter
This is a command-line utility that can be used to convert .vrimg image files to .exr files in OpenEXR format. Find out more: V-Ray Image to EXR Converter
width5%
width20%
UI Text Box
sizemedium
Denoiser Tool
The Denoiser Tool is a command-line utility that can be used to denoise still images or animations outside of SketchUpRhino. Find out more: Denoiser Tool
width5%
width20%
UI Text Box
sizemedium
Plugininfo Tool
A command-line utility that lists V-Ray plugins and detailed description for them. Find out more: Plugininfo Tool
width5%
width20%
UI Text Box
sizemedium
Filter Generator Tool
The Filter Generator is a simple tool for composing filters (HDR images in *.hdr format). It is specially designed to produce filters for the Lens Effects. Find out more: Filter Generator Tool
width5%
width20%
width5%
width20%
width5%
width20%
width5%
GI Tools and Utilities
width20%
UI Text Box
sizemedium
Irradiance Map Viewer
The irradiance map viewer can be used to view, merge and save irradiance map files created by V-Ray. Find out more: Irradiance Map Viewer
width5%
width20%
width5%
width20%
width5%
width20%
width5%
