width20%
UI Text Box
sizemedium
V-Ray Standalone Command-Line Options
The V-Ray Standalone tool is a command-line rendering tool supporting V-Ray's native .vrscene file format.
Location (Windows): Start Menu\Programs\Chaos Group\V-Ray for Rhino\V-Ray standalone command prompt
Location (Mac OS): /Applications/ChaosGroup/V-Ray/V-Ray\ for\ Rhino/extension/vrayappsdk/bin/vray.bin
Find out more: V-Ray Standalone Command-Line Options
width5%
width20%
UI Text Box
sizemedium
V-Ray Image to EXR Converter
This is a command-line utility that can be used to convert .vrimg image files to .exr files in OpenEXR format. Find out more: V-Ray Image to EXR Converter
width5%
width20%
UI Text Box
sizemedium
Denoiser Tool
The Denoiser Tool is a command-line utility that can be used to denoise still images or animations outside of Rhino. Find out more: Denoiser Tool
width5%
width20%
UI Text Box
sizemedium
Plugininfo Tool
A command-line utility that lists V-Ray plugins and detailed description for them. Find out more: Plugininfo Tool
width5%
