width60%
The Light Rig Sun System includes a V-Ray Sun Light and Sky texture plugged in all environment slots.
The Sun direction is visible in the Rhino viewport.
width5%
width35%
Image Modified
Input Parameters
width60%
Light Rig (Generic Data) – This rig should be connected to the V-Ray Renderer's Light Rig input slot.
width5%
width35%
Image Modified
Right-click on the node to see more options.
