width60%
V-Ray Material from Project chooses a V-Ray Material from the current Rhino project. Click on the Arrow to select an existing scene material from a list.
width5%
width35%
Right-click on the node to see more options.
Fancy Bullets
typecircle
  • You can use a preset material for vertex color display. For more information, see the V-Ray Material from File.
  • When the V-Ray Material from Project node is used with V-Ray (CPU) engine, material changes from the Asset Editor are taken into account.
