This page provides information on the V-Ray Dirt Texture.
Multipliers
Anchor | ||||
Section | ||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Same Objects Only
Same objects only: on
Example: Inner Occlusion
It allows the user to invert the effect with respect to surface normals - e.g. instead of crevices, open corners are shaded with the occluded color.
Anchor | ||||
Section | |||||
A bitmap is used in the texmap radius slot. Notice that the main radius parameter still has effect - it determines the amount of area where the texmap radius bitmap would blend.
Section | ||||||||||||||||||||||||||||||||||||||||||
