The Paths & Sharing tab found in the Settings window combines options for exporting .vrscene files, sharing V-Ray for Revit settings across projects and setting asset paths.
width
5%
width
50%40%
Image Modified
V-Ray Scene Export Options
width
50%
55%
Options specific to exporting a V-Ray Scene.
Export Compressed – When enabled, compresses geometry information so that the resulting .vrscene file is smaller. Only valid if Use HEXformat is enabled.
Use Hex Format – Writes geometry information as binary data in order to preserve the data exactly, without the round-off errors introduced by conversion to human-readable form.
Export As Archive – The exported .vrscene is combined with all externally linked V-Ray assets including materials, textures, and IES files into a 7zip file.
width
5%
width
45%
40%
Image Removed
Image Added
Asset Paths
width
50%
55%
Specifies search paths that V-Ray uses to look for materials and proxies at render time.
Use the Add button to locate a path and add it. Use the Remove button, in case you want to remove a path.
width
5%
width
45%
40%
Image Removed
Image Added
width
50%55%
You can choose between Default mode and Sharing mode.
Default
Displays all V-Ray settings that were modified from their default value in a grid view table.
Reset – Users can selectively reset their V-Ray settings to default.
Set As Default – Starts using the current V-Ray settings as default, i.e. they will be used every time when starting a new project.
Purge button () – Deletes all V-Ray materials and resets your V-Ray settings (including material mappings, rpcs, vrscenes, proxy meshes, textures, override materials, etc.) to their defaults.
UI Text Box
type
warning
In a workshared model it deletes all other users' V-Ray settings and V-Ray materials.
width
5%
width
45%40%
Image RemovedImage Added
width
50%55%
Sharing
Categories – Select which categories of V-Ray for Revit settings to be exported or loaded. The following categories are supported:
V-Ray Material - Includes all V-Ray materials saved within the project V-Ray Mapping - Includes the associations between Revit materials and V-Ray ones
UI Text Box
type
note
To import V-Ray materials properly, make sure that in both projects, the one you export from, as well as the one you import to, the corresponding Revit materials have the same names.
Environment – Includes Environment settings, as well as Sun and Dome Light settings. Channels – Include all enabled render elements in the current scene. RPC Proxies – Include all RPC overrides with V-Ray Proxies (.vrmesh or .abc files). Camera – Includes all settings from the V-Ray Camera Settings dialog. Swarm – Includes all distributed rendering settings: Swarm on/off, Goal (resource usage), Auto-Discovery on/off, Master Node IP, Tags.
Export – Exports the selected Categories to a .xml file which can be loaded further in another project.
Load – Loads the selected Categories from a .xml file to the current project. The settings which had been exported to the .xml file and differ from the current project’s settings will appear in the Import List below. Users select which settings they want to import by unchecking those they do not want.
Load from Project Storage– In case the Revit project is workshared, allows for loading other coworkers' settings and adopting them. Note that when you import those settings, yours will be overridden.
Import – Imports the selected settings from the Import List into the current project.
Discard – Clears the Import List, in case the user wants to load another .xml file.
