1. Start the DR server on the slave machine. To do that, open the cmd and run "C:\Program Files\MAXON\Cinema 4D Rnn\plugins\V-Ray\res\libs\win64\vray.exe" -server
If you are using more than one render slave machine, you have to perform this operation on each of them!
UI Text Box
type
tip
You can also start the render slave from the Start Menu > V-Ray for Cinema 4D > Launch V-Ray render slave.
UI Text Box
type
note
When installing V-Ray for Cinema 4D and choosing Installation type: Standalone, note that the location of the vray.exe file will be in C:\Program Files\Chaos Group\V-Ray\Cinema 4D\bin\vray.exe .
width
5%
width
35%
width
60%
2. On the render client machine, go to Cinema 4D's Render Settings > V-Ray > Common > Distributed Rendering and enable Distributed Rendering. Then, press the Render Hosts button and open the V-Ray Distributed Rendering window.
What you need to do now, is to add the render slaves IP's. That is the IP address of the machines that will do the render job.
You can add as many render slaves as you wish.
UI Text Box
type
note
The default Port is 20207. Please leave it as it is if you don't specifically know that you need something else.
All render slaves use the same port.
width
5%
width
35%
width
60%
3. Render the scene.
You can see the rendering process via the new VFB.
width
5%
width
35%
Tabs Page
title
macOS
width
60%
1. Start the DR server on the slave machine. To do that, open the Terminal and run "/Applications/MAXON/Cinema\ 4D\ Rnn/plugins/V-Ray/res/libs/osx/vray -server"
UI Text Box
type
note
When installing V-Ray for Cinema 4D and choosing Installation type: Standalone, note that the location of the vray file will be in /Applications/ChaosGroup/V-Ray/bin/vray .
width
5%
column
width
35%
Image Removed
width
60%
UI Text Box
type
note
width
5%
width
35%
Image Added
width
60%
