UI Path: ||V-Ray Frame Buffer|| > Layers > Lens Effect
Image Added
Image Removed
width60%
V-Ray Lens Effects simulates real-world camera lens effects such as bloom and glare. The plug-in uses a fast multi-threaded technique to compute the result and provide immediate update in New V-Ray VFB. V-Ray Lens Effects are applied in the effectsResult channel together with other post effects executed over the RGB rendered image.
The Lens Effects layer is accessible from the Layers panel in the new VFB and can be activated when the lens effects are enabled. It can be blended with the rest of the layers in the redesigned VFB.
Additionally, V-Ray includes a standalone Lens Effects Generator Tool for composing custom lens filters.
ui-expand
UI Text Box
typetip
Lens Effects layer can be disabled from the visibility icon ().
title
width5%
width35%
