width57%
The Raw Sheen Reflection Filter Render Element is similar to the Sheer Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
UI Path: ||V-Ray|| > Render Elements > Raw Sheen Filter
width5%
width38%
 Image Added
Properties
width57%
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width38%
