VRayPluginNodeMtl allows you to create a material from V-Ray Standalone material plugin that comes with the V-Ray installation. This ensures that all VRayPluginNodeMtl materials will work with V-Ray Cloud and there will be is no difference in fine details like noise seed and others. Furthermore, it gives you access to a lot of handy plugins used by V-Ray throughout different platforms.
For example, BRDFGlass can be created and assigned to an object by itself, but Mtl2Sided will expect expects other BRDF or Mtl plugins to be specified as its front and back materials.
UI Expand
titleUI Path: ||Material Editor window|| > Material/Map Browser...
||Material Editor window|| > Material/Map Browser > Materials > V-Ray > VRayPluginNodeMtl
width20%
width60%
width20%
