- Unzip the V-Ray for Houdini archive
- Move it to a location of your choice (e.g. "D:/V-Ray")
- Place the "vray_for_houdini.json" file under "$HFS/packages"
- Edit the "vray_for_houdini.json" and set the "INSTALL_ROOT" variable to point to the location of the V-Ray files (e.g. "INSTALL_ROOT" : "D:/V-Ray")
- Start Houdini
Linux and
macOS
In Linux or Mac macOS envronment, the process is exactly the same.
For macOS: Note that the "packages" folder resides in Applications > Houdini > Houdini 18.5.XXX > Frameworks > Houdini.framework > Versions > 18.5 > Resources > packages > ...
For detailed information on how to run V-Ray for Houdini, see the QuickStart Guides Introduction tutorial.
