V-Ray File Path Editor is a file managing tool that lets you set file paths, create scene archives, and keep track of different assets. Find out more:V-Ray File Path Editor
width
5%
width
20%
UI Text Box
size
medium
V-Ray Menu
V-Ray menu provides access to the most common V-Ray options, such as Frame Buffer and Asset Editor. Find out more: V-Ray Menu
width
5%
width
20%
UI Text Box
size
medium
V-Ray Commands in Rhino
V-Ray for Rhino has a number of set commands executable through the main Rhino Command window. Find out more: V-Ray Commands in Rhino
width
5%
width
20%
UI Text Box
Object Properties Panel
Rhino Object Properties panel offers some V-Ray functionalities. Find out more: Object Properties Panel
Fancy Bullets
type
circle
Anchor
sRGB
sRGB
Hovering with the cursor over each color box in the Asset Editor displays a tooltip with the color value in RGB format with a range of 0 to 1 in Screen (sRGB) color space.
