changes.mady.by.user Kristin Ivanova
Saved on Dec 30, 2020
Saved on Apr 28, 2021
The Object ID Render Element creates selection masks based on Object ID that shows each object (by Object ID) in a solid unshaded color.
UI Path: ||V-Ray|| > Render Elements > Object ID
Image Added
How to add a render element to a scene Image Removed
Enable Deep Output – When enabled, the render channel is rendered in the V-Ray Virtual Frame Buffer.
