width57%
The Raw Lighting Render Element stores the effects of direct lighting on scene objects with no diffuse components. It is useful for adjusting the brightness of direct lighting during compositing.
UI Path: ||V-Ray|| > Render Elements > Raw Lighting
width5%
width38%
Image Added
How to add a render element to a scene Image Removed
Properties
width62%
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for AaAnti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width33%
