This page describes the ply2vrmesh command-line utility.
The ply2vrmesh command-line utility can convert .ply, .obj, .bin, .geo, .bgeo, .hclassic, .bhclassic, .abc and .vrscene files to .vrmesh files for rendering with V-Ray through V-Ray Proxy Objects .
UI Paths
Currently, on all operational systems the ply2vrmesh.exe is located in V-Ray's folder (where the V-Ray files are extracted) > appsdk > bin
Excerpt Include
VRAY4TOOLS:OBJ GEO PLY to .vrmesh converter
nopaneltrue
Fancy Bullets
typecircle
  • The converter works with most of the popular .ply formats, both ASCII and binary, big-endian, or little-endian.
  • In addition to the geometric data (faces and vertices), the converter recognizes some of the most common additional channels such as diffuse surface color. Vertex colors are recognized if they are specified as "red", "green", and "blue" or "diffuse_red", "diffuse_green", and "diffuse_blue" vertex properties.
