width40%
All options under the Rendering rollout are supported by V-Ray Adv (CPU).
The following options are not supported by V-Ray GPU:
  1. Smoke Color → Scattering: Approximate & Approximate+Shadows - V-Ray GPU is significantly faster when using the Ray-Traced (GI Only) option. V-Ray Global Illumination should be enabled for this option to have any effect.
  2. Smoke Color → Volume Light Cache: . This option refers to the internal Phoenix Light Cache which is not related to the V-Ray Light Cache. It's a CPU-only feature that helps speed up Bucket rendering.
  3. Fire Lights: All Fire Lights options are ignored when rendering with V-Ray GPU. Enable Global Illumination from the V-Ray Settings if you need the Smoke and/or the scene to be illuminated by the fire.
width60%
Image slider
Panel
borderStylenone
V-Ray Next Adv. CPU with Brute Force / Brute Force GI
Panel
borderStylenone
V-Ray Next GPU with Brute Force / Brute Force GI
