Anchor
RedshiftRendering
RedshiftRendering
How to render Phoenix VDB caches with Redshift
UI Text Box
sizemedium
typeinfo
 The video below shows how to render Phoenix VDB caches with Redshift.
Anchor
ArnoldRendering
ArnoldRendering
How to render Phoenix VDB caches with Arnold
size
UI Text Box
mediumtypeinfo
 The video below shows how to render Phoenix VDB caches with Arnold.
Anchor
restore
restore
How to restore а Phoenix simulation
UI Text Box
sizemedium
typeinfo
 The video below shows how to restore a Phoenix simulation.
Anchor
backburnerSim
backburnerSim
Simulation with Phoenix using Autodesk Backburner
UI Text Box
sizemedium
typeinfo
 The video below shows how to run a Phoenix simulation using Autodesk Backburner.
UI Expand
titleSimulation with Autodesk Backburner
UI Steps
sizesmall
UI Step
Click the Phoenix FD Simulator → Output roll-out rollout → Set output cache file location.
UI Step
Start Backburner Manager, Server and Monitor.
UI Step
In the Backburner Monitor go to Manager → Connect manager and set the corresponding IP adressaddress.
UI Step
Click the Phoenix FD top menu → Submit Simulation to Backburner.
UI Step
Set the name or the ip address for the Backburner Manager.
UI Step
Turn on "Run only the Simulation and do Not Render".
UI Step
Press the "Run" button.
UI Expand
titleUsing Phoenix FD Wetmap
UI Steps
sizesmall
UI Step
Click the Phoenix FD Simulator → Liquid roll-out rollout → Enable "Wetting".
UI Step
Click the Phoenix FD Simulator → Output roll-out rollout → Make sure that the Wetmap particles are enabled for export.
UI Step
Open the Hypershade and create two V-Ray materials.
UI Step
Create a V-Ray Blend Material and connect the already created V-Ray materials as Base color and Coat 1.
UI Step
Create a Phoenix FD Particle Texture → Edit Particle Systems → Select the phxParticleTex_set and connect it to the PG_PhoenixFDSimulator_WetMap.
UI Step
Connect the Phoenix FD Particle Texture as a blend amount mask for the V-Ray Blend Material.
UI Step
Assign the V-Ray Blend Material to your geometry and render.
Anchor
exportAlembic
exportAlembic
How to export a Phoenix cache to Alembic
UI Text Box
sizemedium
typeinfo
 The video below shows how to export a Phoenix cache to an Alembic file.
UI Expand
titleExporting the Liquid Mesh
UI Steps
sizesmall
UI Step
Set Phoenix FD Simulator → Rendering roll-out rollout → Mesh sub-roll-out rollout Mesh Type: Maya Mesh (not suitable for Ocean).
UI Step
Double-check to make sure the Velocity Color Set field at the bottom of the Mesh roll-out rollout is set to velocity.
UI Step
Select the liquid mesh and go to Cache → Alembic Cache → Export Selection to Alembic (option box).
UI Step
From the Alembic Export Options dialog, make sure Write Color Sets is enabled under the Advanced Options roll-out rollout.
Anchor
exportVDB
exportVDB
How to export a Phoenix simulation to OpenVDB
medium
UI Text Box
size
typeinfo
This video shows how to set the output format to OpenVDB and import the cached simulation inside of a V-Ray Volume Grid.
UI Expand
titleExporting OpenVDB
UI Steps
sizesmall
UI Step
Click the Phoenix FD Simulator → Output roll-out rollout → '...' button next to the Simulation Save Path option.
UI Step
Select Browse and navigate to a preferred folder. Set the File Name option and choose OpenVDB Cache from the Files of Type drop-down.
UI Step
Start the simulation as usual. The output cache files are now OpenVDB instead of AUR.
