4) By default, V-Ray Swarm's Network Discovery is set up to auto-discover machines on the network. If the Use auto-discovery option is disabled, the custom configuration of the manually set Master Node Coordinator IP becomes available. This option is suitable if there is more than one subnet in the LAN or if you want to dedicate one or more machines to be Master NodesCoordinators. You may choose three machines as master nodesCoordinators: one primary Master Node Coordinator (Master node Coordinator IP) and two alternate Master Nodescoordinators.
5) When the installation process is complete, click the Finish button.
