||Particle View window|| > Depot > PhoenixFD Force
Image RemovedImage Added
width
50%
||Particle View window|| > Event Display quad (right-click) menu > New > Operator Event > PhoenixFD Force
width
100%
Image Removed
60%
Phoenix Simulator Simulator| node – Which Simulator to read the Grid Velocity from.
InfluenceInfluence | influence – Determines how strong the fluid holds the particles. A value of 100% means that the particle will follow the fluid exactly. A value of less than 100% causes the particle's speed to only approach the fluid's speed. For example, a value of 10% means that at every integration step the velocity of the particle will overcome 10% of the difference between its velocity and fluid's velocity.
Ignore Time Scale | ignore_time_scale – When enabled, the Play speed parameter of the Simulator is not taken into consideration.
Affect Orientation | rotate – When enabled, the particle is rotated in correspondence to the fluid's motion.
Delete Particle Outside | delout – When enabled, particles which exit the Simulator's grid will be deleted. Note that the grid size of the loaded cache by the simulator will be used for this check and if there is no loaded cache, no particles will be deleted.
Time Source | timesrc – Same as the Offset Influence→ Sync Byparameter of the 3ds Max Force operator. It describes how to calculate the time argument passed in animatable parameters (in our case only the influence is affected). For example, if you set Time Source to Particle Age and you animate the Influence from 100.0 at frame 0, to 0.0 at frame 10, this means that newborn particles will initially be affected by the Phoenix Force with 100% Influence, and over 10 frames since the birth of the particle the Influence would decline until the fluid stops affecting the particle completely. This way no matter how early or late in the simulation a particle is born, the Influence would affect it depending on the time of its birth and not depending on the current timeline frame.
