User attribute name – Specifies the name of the user attribute that is looked up and returned from this shading node.
Default color – Specifies the color to return if the user attribute is not found on the shaded object.
Required format for attribute name – Displays possible formats for the attribute in the V-Ray User Attributes string assigned to the object and what is rendered as a result.
width
5%
width
33%
How to Render Vertex Colors
width
62%
The VRayUserColor texture can be used to render objects colored with vertex color painting.
Here is how it’s done:
Create a VRayMtl and assign it to the object that has painted vertex colors.
Create a VRayUserColor texture and link it to the Diffuse map slot of the VRayMtl.
width
5%
width
33%
Image Added
width
62%
3. Open the Color Set Editor from Mesh Display > Color Set Editor and select the object in the viewport. This displays the available color sets in the Color Set Editor dialog.
width
5%
width
33%
Image Added
width
62%
4. In the Color Set Editor, copy the color set name by double clicking on it and then pressing Ctr+C.
width
5%
width
33%
Image Added
width
62%
5. Paste the name in the User attribute name field and render.
width
5%
width
33%
Image Added
Fancy Bullets
type
circle
When rendering with IPR GPU, VRayUserColor supports setting UV and color sets from proxies and regular geometry.
