Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
The DR Check tool can be used to query the state of render slavesservers, the number of processors on the slave machine server machine and the V-Ray version of the slaveserver.
Depending on your OS, the vraydr_check executable is located as follows:
Note: IP is the IP address of the machine that is running a V-Ray slave and render server and num is the number of the port (by default it's 20207). Example: vraydr_check -host=10.0.0.100 -port=20207
Fancy Bullets | ||
In case a connection cannot be established with the slaveserver, the tool will print this message: Failed to connect to server 1.0.0.100:20207
This could mean that either something is blocking the connection, or the slave is server is not running at all on the specified IP address.
