Section | ||||||||||||||||||||||||||
The following example will print the name of the simulator (node) , the current time (t) and the current time step (dt). The The if() statement is used to stop the simulation if the current frame is 2. You can save the script below to a test.py file for Python or test.mel file for MEL and load it from Phoenix Simulator → Simulation → Scripting → Script File.
Function Declaration
Example MEL function declaration:
