The following example will print the name of the simulator (node) , the current time (t) and the current time step (dt). The if() statement is used to stop the simulation if the current frame is 2.
You can save the script below to a test.py file for Python or test.mel file for MEL and load it from Phoenix Simulator → Simulation → Scripting → Script File
width26%
PYTHON 3 (used for Maya 2022 and newer):
Code Block
import maya.cmds as cmds
import phxfd
def OnNewFrame(node, t, dt):
    print (node)
    print (t)
    print (dt)
    if( cmds.currentTime(query = True) == 2 ):
        phxfd.stop()
width26%
PYTHON 2 (used for Maya 2021 2020 and older):
Code Block
import phxfd
    print node
    print t
    print dt
        phxfd.stop()
width26%
MEL:
Code Block
global proc OnNewFrame(string $node, float $t, float $dt) {
    print $node;
    print $t;
    print $dt;
    $now = `currentTime -q`;
    if($now == 2){
        phxfdSim -n $node -a "stop";
