width70%
The V-Ray UVWGenObject node allows you to use Object mapping within the Mat Network.
UI path:
||mat Network|| > V-Ray > Texture: Mapping > V-Ray UV Object||out Network|| >
 V-Ray Render Elements node > V-Ray > Texture: Mapping > V-Ray UVObject
width5%
width25%
