Code Block
// Fatal error freeing exporter memory. //
// There was a fatal error building the scene for V-Ray. //
// There was a fatal error updating the scene for V-Ray. //
// Fatal error clearing key frames. //
// Fatal error baking node. //
// Fatal error rendering scene. //
If you see a Fatal Error message when rendering, contact the Chaos Group support team with information on how to reproduce the crash. Usually, sharing a scene and the V-Ray logs, along with any steps to reproduce the issue helps the team identify and fix the problem.
An Unhandled exception message means that V-Ray has encountered a crash and and has managed to catch the error while preventing the application from exiting directly to desktop.
If you see an Unhandled exception message when rendering, contact the Chaos Group support team with information on how to reproduce the crash. Usually, sharing a scene and the V-Ray logs, along with any steps to reproduce the issue helps the team identify and fix the problem.
Code Block
// Warning: V-Ray : Scene bounding box is too large, possible raycast errors. //
In general,  it's safe to ignore this warning, as it may appear when rendering very large scenes, but the chance of actual rendering errors is very slim. However, if you experience issues that you think are related to a very large scene scale, please contact the Chaos Group support team. Keep in mind that sharing a scene and the V-Ray logs, along with any steps to reproduce the issue helps the team identify and fix the problem.
Check the Maya plugin manager from the Maya Windows menu > Settings/Preferences > Preferences > Plug-in Manager. Click Loaded for  for vrayformaya.mll and enable Auto load for V-Ray to load each time Maya starts.
In case V-Ray cannot load at all, contact the Chaos Group support team.
Node is not expected as texture input
