Code Block
languagejava
titleExample JSON file for loading V-Ray
	"env": [
		{ "INSTALL_ROOT" : "C:\/Program Files\/Chaos Group\/V-Ray\/Houdini 1819.0.532383" },
		{ "VRAY_APPSDK"     : "${INSTALL_ROOT}/appsdk" },
		{ "VRAY_OSL_PATH"   : "${INSTALL_ROOT}/appsdk/bin" },
		{ "VRAY_UI_DS_PATH" : "${INSTALL_ROOT}/ui" },
		{ "VFH_HOME"        : "${INSTALL_ROOT}/vfh_home" },
		{ "PYTHONPATHPATH" : [
			"${INSTALL_ROOT}/appsdk/python27" HFS}/bin",
			"${VRAY_APPSDK}/bin",
			"${VFH_HOME}/bin"
		{ "VFH_DSO_PATH" : {
			"houdini_python : [== 'python2'": "${VFH_HOME}/dso_py2",
			"houdini_python == 'python3'": "${HFS}/bin;VFH_HOME}/dso_py3"
		{ "PYTHONPATH" : [
			{ "method": "append", "houdini_python == 'python2'": "${VRAY_APPSDK}/binpython27" },
			{ "method": "append", "houdini_python == 'python3'": "${VFHVRAY_HOMEAPPSDK}/binpython37" }
		{ "VFU_PLUGINS" : "${VFH_DSO_PATH}/usd_plugins/hdVRay/plugins" },
		{ "HOUDINI13VFH_VOLUMEASSET_COMPATIBILITYPATH" : 1"C:/Users/USER/Documents/V-Ray Material Library/assets" },
		{ "HDF5_DISABLE_VERSION_CHECK"     : 1 HOUDINI_DSO_PATH" : "${VFH_DSO_PATH}" },
		{ "HOUDINI_GALLERY_PATH": [
			{ "method": "append", "value": "${VFH_HOME}/gallery" }
	"path" : [
		"${VFH_HOME}"
Windows
To deploy V-Ray using the ZIP archive instead of the installer:
