Render Elements are a way to break out renders into their component parts such as diffuse color, reflections, shadows, mattes, etc. This gives fine control over the final image when using compositing or image editing applications when re-assembling the final image from its component elements. Render elements are also sometimes known as render passes.
Render Elements are generated at render time based on the ones you choose before rendering. Most render elements have parameters that can be set to customize the render element or its later use in compositing software. These parameters are described on each render element's individual page, along with common uses and any notes on their generation and usage.
For more details on what render elements are available within V-Ray for Maya, please see the Render Elements section. This includes a breakdown of each pass and what it's used for.
UI Expand
title
UI Path: ||Render Settings window|| > Render Elements tab
