width50%
The Global Illumination Render Element is a color image that stores indirect lighting information coming from reflected diffuse light in a scene (without direct light and reflection contributions) when Global Illumination is enabled in Render Settings. This element may be used directly in Back to Beauty compositing and adjusted for brightness and color to control the final image easily.
For even more control of indirect illumination without re-rendering the scene, the Global Illumination render element may be re-assembled by multiplying the Raw Global Illumination Render Element by the Diffuse Render Element:
Raw GI x Diffuse = GI
UI Path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Color Channel (RE) > Type > GI
width5%
width45%
Image Modified
Attributes
width50%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings will be are applied to the current render channel.
Consider For AA – When enabled, anti-aliasing will be is used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of the    V-Ray Renderer node.
Denoise – Enables the render element's denoising, provided the Denoiser render the V-Ray Denoiser render element is present.
VFB Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width45%
Image Modified
Common Uses
