The Subsurface Scattering Render Element stores subsurface information from the V-Ray SSS material as an image. This render element can then be used to enhance or color-correct just the subsurface scattering component of the image during the compositing process.
UI path: ||out Network||> V-Ray Render Elementsnode > V-Ray > Render Channel >V-Ray Color Channel (RE)> Type > SSS
width
5%
width
45%
Image Modified
Attributes
width
50%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings will be are applied to the current render channel.
Consider For AA– When enabled, anti-aliasing will be is used where possible.
