The example shown here shows the shader ball with a reflective material lit by an environment light with a V-Ray Softbox Texture applied.
UI Paths: ||mat Network|| V-Ray > Texture: Procedural > V-Ray Softbox
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Procedural > V-Ray Softbox
width10%
width40%
Image Modified
width40%
Image Modified
width10%
width50%
Enable – Enables the frame gradient.
Frame Vignette Flip – When enabled, reverses the frame gradient.
Use Frame Tint – Enables the frame tint.
Tint Color – Specifies a color to tint the frame.
Tint Strength – A multiplier that controls how strong of an effect the Tint Color has.
Enable Frame Noise – Enables frame noise.
Noise Amount – Specifies Controls the amount of frame noiseeffect the Noise has on the gradients.
Noise Size – Specifies the scale of the frame noise function.
Noise Phase – Specifies Controls the phase speed of the frame noise procedural animation.
Fractal Noise – When enabled, generates a fractal noise pattern.
Fractal Levels – When Fractal Noise is enabled, this controls the number of fractal iterations.
width5%
width45%
width50%
Enable – Enables or disables the hot/dark spot.
Spots Mode – Specifies how the hot/dark spot is applied.:
Hot Spot – Color is added to the texture, adding brightness and creating a hot spot. See the Hot Spot vs Dark Spot example below.
Dark Spot
– Color is subtracted from the texture, removing brightness and creating a dark spot. See the Hot Spot vs Dark Spot example below.
Softness – Controls the rate at which the hot spot fades out.
Inner Radius – Specifies the inner radius where the hot spot begins to fade out as a fraction of the texture size.
Outer Radius – Specifies the outer radius where the hot spot ends as a fraction of the texture size.
Spots Multiplier – A multiplier for the brightness of the hot/dark spot.
U/V Offset – Controls the position of the spots along the U or V axis.
U/V Tiling – When enabled, controls the tiling of the spots along the U or V axis.
Spots Tint On – Enables the tint color for the spots.
Spots Tint Color – When enabled, controls the color of the hot spot.
Spots Tint Strength – A multiplier that controls how strong the strength of the Tint Color parameter.
width5%
width45%
width50%
Default Color – Specifies the color when there are no valid UVW coordinates.
Mult – Specifies a strength multiplier for the texture color.
Offset – Color corrects the texture by adding the the RGB color values specified here to the RGB color values in the texture.
Invert – When enabled, inverts the resulting texture color.
width5%
width45%
width50%
Source – Specifies where the alpha channel is drawn from.
Alpha – Alpha channel is drawn from the texture.
Color
– Alpha is generated from pixel intensity.
Opaque
– Alpha channel is fully opaque.
Use – Differentiate – Differentiates between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
Offset – Specifies an additional offset for the texture alpha.
Invert – When enabled and Invert from Color Tweaks is also enabledon, the resulting texture alpha is inverted as well.
width5%
width45%
width50%
Placement Type – Specifies the way the valid portion of the texture is applied.
Full – Uses the full valid portion of the texture.
Crop – Allows the user to specify Specifies a section of the texture using the parameters below.
Place – Allows the user to specify Specifies a section of the texture and how to place it using the parameters below.
U – Specifies the U coordinate of the valid texture sector.
V – Specifies the V coordinate of the valid texture sector.
W – Specifies the width of the valid texture sector.
H – Specifies the height of the valid texture sector.
Jitter – Controls the amount of random placement variation.
Tile U – Enables horizontal tiling.
Tile V – Enables vertical tiling.
width5%
width45%
The Gradients options allow the user to blend gradient textures on top of the V-Ray Softbox texture. You can add a gradient in the U and V direction and place a frame - which is a gradient in both directions.
Anchor
spotsEx
spotsEx
Example: Hot Spot vs Dark Spot
This example shows the difference between Hot Spot and Dark Spot modes. The Base Color is grey and the Tint Color is white. The Multiplier is set to 0.1.
width20%
width60%
Image slider
afterLabelDarkSpot
startIndex1
beforeLabelHotSpot
Panel
borderStylenone
Image Added
V-Ray Softbox texture with Spot options disabled
Panel
borderStylenone
Image Added
V-Ray Softbox texture with Hot Spot mode selected
Panel
borderStylenone
Image Added
V-Ray Softbox texture with Dark Spot mode selected
width20%
