Ver 5.20.20, API Version 3.10.00
Date - 3 Feb, 2022
Highlights
- Native Arm M1 and Mac OS BigSur support
- Added the Material Library
- New UV Texture Sampler
- Added Node.js v14, v16 and Electron v11 bindings. All are now context aware
- Added Python 3.9 binding
Features
- If VRAY_SDK environment variable is set, %VRAY_SDK%\bin is used to locate VRaySDKLibrary and V-Ray binary files by default
- Added BinUserAttributesWriter
- [Node.js] Added for-of loop iterator to VRayRenderer.plugins
- [Node.js, Electron] Binding modules are now context aware
- Added VRayRenderer.waitForVFBClosed() function
- Updated ScannedMaterialParams and ScannedMaterialPresets; removed their setDefaults() and reset() methods
- Added a confirmation dialogue for the VFB 'Clear image' action as well as functions to enable/disable it and get its state
- Added clearPropertyValuesUpToTime(double time, PluginCategories categories)
- [C++] Added Plugin value getters to the optional V-Ray SDK interoperability layer
- Added vfb.setProgressTextAndValue()
- [C++, .Net] Added setGUIMessageProcessing() to allow disabling internal VFB message pumping
- Added VRayRenderer::clearPropertyValuesUpToTime(double time, PluginCategories categories)
- Added VRayRenderer::getChangeIndex()
- Added useVfbLog flag to RendererOptions
- Added RenderElement::getMetadata()
- UV Texture Sampler: [C++ and C#] Added a new UVTextureSampler class. It can be used for sampling VRay texture plugins at different u-v points. Also the sampling does not require a rendering license as it does not start the whole rendering process. The sampler class is lightweight and fast to set up but note that it might not always return satisfying results when used with more complex texture plugins.
- Improved V-Ray Proxies support:
- Export hair and particle voxels from Plugin and MeshFileData input,
- Read and export the edge_visibility data and the voxel info channel to a mesh file,
- Faster execution speed of readFullData().
Version 5.10.01, API Version 3.00.00
Date - 5 Mar, 2021
Highlights
* New V-Ray VFB (codenamed VFB2).
* Share VRayRenderer instances among programming languages.
* [C++] Added move semantics to the Value type and the Plugin property setters.
C++11 is now required to use AppSDK in C++.
* Added Python 3.8 binding.
* Added .Net Core builds.
Features
* [VFB2] Added functions to get/set VFB2 settings as JSON.
* [VFB2] Added an update notification event/callback to VRayRenderer.
* [VFB2] Added LightMix Transfer To Scene event/callback to VRayRenderer.
* [VFB2] Added a flag to disable the VFB2 Transfer To Scene button to RendererOptions.
* [VFB2] Window handle functions:
- Added getNativeHandle(), getQWidget(), setNativeParentWindow(),
setQWidgetParent() and getMinimumSize();
- Marked getWindowHandle() and setParentWindow() as deprecated/obsolete.
* Added the ability to share the same VRayRenderer instance among different
programming languages:
- Added VRayRenderer.getInstanceHandle() method
(InstanceHandle read-only property in C#);
- Added VRayRenderer(instanceHandle) constructor.
* Added new checkDRHost(hostString) function that checks whether a VRayServer instance
is listening on a given host/port and returns info about it if it is.
* Filter the available CUDA and Optix devices in their corresponding get and set
functions;
* Exposed CUDA Compute Capability info.
* Added vfb.loadBackgroundImage() to load VFB CC background image.
* [Python] Completely removed old list wrapper type.
* denoiseNow() now accepts an optional "ready" callback function.
* [C++, .Net] Added two new methods get/setRenderSizes which get/set all ImageSize,
CropRegion and RenderRegion parameters and the state of the VFB region button state.
* Added VFB::clearImage() and VFB::resetState() methods.
* [C++] Added overloads with move semantics to loadAsText/appendAsText functions.
* [.Net] Added ToString() to Plugin and PluginRef.
* [.Net] Added GetHashCode() and Equals() methods, and operator== to PluginRef and PluginLink.
* Disallowed invalid characters in plugin names; Added allowInvalidCharactersInPluginNames
flag to RendererOptions to force old behavior and allow them.
* [.Net] Throw exception if creating a new plugin fails. In most cases it would happen
because of the new bad plugin name checks.
* [Node.js, Python] Changed vfb.saveImage to use the default ImageWriterOptions
if the user hasn't passed any options at all as it is in C++ and .Net
* Changed ImageWriterOptions in all languages to always set IWI_MULTI_CHANNEL
(i.e. produce a single multi-channel file if the file format supports it)
* [Node.js, Python, Windows] Fixed setSDKLibraryPath() in Node.js and Python didn't work
with relative paths. Now it works with both absolute and relative paths.
Also full VRaySDKLibrary path is now returned by getSDKLibraryErrorString()
if the file has been found and loaded.
* Removed gpuPluginPath member from RendererOptions.
* [C++, .Net] Added callbacks for color corrections and compositing layer changes in VFB.
* [C++] Added the missing setValue(double) and getDouble methods to Plugin class.
* Added returning default values of TYPE_TEXTURE* plugin property types.
* Added Object Select render element.
* Added cameraName setters/getters to easily switch cameras which has the scene_name
property.
* [.Net] Replaced VRayImage.ToBitmapImage() with VRayImage.ToBitmapStream() in order
to avoid GDI+ dependency.
* Changed the current frame and time logic when rendering a sequence. Now the current
frame and time are changed before the wait for sequence continue is started.
VRayRenderer::getCurrentTime() and VRayRenderer::getCurrentFrame() now return
the time or frame number of the next frame that will be rendered in the sequence.
Also aborting the renderer while it is waiting to continue the sequence will
leave the next frame number as current time of the renderer.
