Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Render Settings.
Common Use Examples
width5%
width40%
Image Added
Two Sided material is commonly used for leaves. Notice how the light illuminates the shrub from behind.
width10%
width40%
Image Added
The curtain uses Two Sided material to allow some outdoor light on the inside of this interior.
width5%
Example: Nightstand Lamp
In this example, the lampshade uses a Two Sided material with only a Front material connected (VRayMtl). A V-Ray sphere light is used to illuminate the inside. Translucency is shown here with grayscale values (RGB).
width30%
width40%
Image slider
Panel
borderStylenone
Image Added
Translucency (0, 0, 0)
Panel
borderStylenone
Image Added
Translucency (64, 64, 64)
Panel
borderStylenone
Image Added
Translucency (128, 128, 128)
Panel
borderStylenone
Image Added
Translucency (192, 192, 192)
width30%
Example: Leaf
In this example, the leaves have both front and back materials connected to the Two Sided Material. Notice how the leaves change when the Translucency value (shown in RGB) is changed. The last render uses a Translucency grayscale map.
width30%
width40%
Image slider
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Translucency (255, 255, 255)
Panel
borderStylenone
Image Added
Translucency map
width30%
Fancy Bullets
typecircle
  • This material will give best results when assigned to single-sided (open mesh/polysurface) objects like planes, extruded splines, etc. Otherwise it can lead to extremely longer render times.
  • The Two Sided material can be made visible only from one side by having its Front material slot empty and the Back material slot filled in.
