Floatingpagetoc
This page provides information about the supported .vrscene features exported from V-Ray for 3ds Max.
UI Text Box
typenote
 Chaos Vantage has better support for .vrscene files exported from V-Ray Next, V-Ray 5.
Lights
 UINative nameV-Ray plugin name (plugin/parameter)Support
Standard 3ds Max light
On
enabled(tick)
Light Type:
Spot
Directional
Omni
LightSpotMax
LightDirectMax
LightOmniMax
(tick)
(tick)
(tick)
Targeted(tick)
Shadowsshadows(tick)
Use Global Settingsuse_global_light_level(tick)
Shadow Type
Adv. Raytraced
Area Shadows
Shadow Map
Ray Traced Shadows
VRayShadow
(minus)
(minus)
(minus)
(minus)
(tick)
Exclude...
SettingsLightLinker/ignored_lights
SettingsLightLinker/ignored_shadow_lights
(error)
(error)
Transparent shadows –(minus)
BiasshadowBias (tick)
Area shadow:
Box
Sphere
shadowShape=0
shadowShape=1
(tick)
(tick)
U sizeshadowRadius
(tick)
V sizeshadowRadius1
(tick)
W sizeshadowRadius2
(tick)
SubdivsshadowSubdivs
(error)
Multiplierintensity
(tick)
Colorcolor
(tick)
Decay Type:
None
Inverse
Inverse Sqaure
decay_type=0
decay_type=1
decay_type=2
(tick)
(tick)
(tick)
Decay Startdecay_start(tick)
Near Attenuation:
Use
Show
Start
End
near_attenuation
near_attenuation_start
near_attenuation_end
(tick)
(minus)
(tick)
(tick)
Far Attenuation:
Use
Show
Start
End
far_attenuation
far_attenuation_start
far_attenuation_end
(tick)
(minus)
(tick)
(tick)
Show Clone(minus)
Overshootovershoot(tick)
Hotspot/Beamhotspot(tick)
Falloff/Fieldfallsize(tick)
Cirleshape_type=0(tick)
Rectangleshape_type=1(tick)
Aspectrect_aspect(tick)
Bitmap Fit...(minus)
Contrast(minus)
Soften Diff. Edge(minus)
DiffuseaffectDiffuse(tick)
SpecularaffectSpecular(tick)
Ambient Only
Mapprojector_map(tick)
Object Shadows:
Color
Density
Map
Light Affects Shadow Color
shadowColor
(error)
(minus)
(minus)
(minus)
Atmosphere Shadows:
On
Opacity
Color Amount
(minus)
(minus)
(minus)
V-Ray Lights
 V-Ray Light
Onenabled(tick)
Type:
Plane
Dome
Sphere
Mesh
Disk
LightRectangle/is_disc=0
LightDome
LightSphere
LightMesh
LightRectangle/is_disc=1
(tick)
(tick)
(tick)
(error)
(tick)
Targeted(tick)
Length/Radiusu_size(tick)
Widthv_size(tick)
Units:
Default (image)
Luminous power (lm)
Luminance (lm/m2/sr)
Radiant power (W)
Radiance (W/m2/sr)
units=0
units=1
units=2
units=3
units=4
(tick)
(tick)
(tick)
(tick)
(tick)
Multiplierintensity(tick)
Mode:
Color
Temperature
(tick)
(tick)
Colorcolor(tick)
Temperaturecolor(tick)
Texture
LightRectangle/use_rect_tex
LightDome/use_dome_tex
LightMesh/use_tex
(tick)
(tick)
(error)
Texture Map
LightRectangle/rect_tex
LightDome/dome_tex
LightMesh/tex
(tick)
(tick)
(error)
Restex_resolution
(tick)
DirectionalLightRectangle/directional
(tick)
Preview:
Selected
Always
Never
(minus)
(minus)
(minus)
Preview texmap(minus)
Spherical (full dome)LightDome/dome_spherical
(tick)
Affect alphaLightDome/affect_alpha(error)
Lock texture to icon(minus)
Ray dist:
None
From GI
Explicit
LightDome/dome_rayDistanceMode=0
LightDome/dome_rayDistanceMode=1
LightDome/dome_rayDistanceMode=2
(error)
(error)
(error)
DistanceLightDome/dome_rayDistance(error)
Target radius(minus)
Emit radius(minus)
Adaptive domeLightDome/dome_adaptive(error)
Flip normals(minus)
Pick meshLightMesh/geometry(error)
Replace mesh with light(minus)
Extract mesh as node(minus)
Exclude
(error)
Cast shadowsshadows(error)
Double-sideddoubleSided
(tick)
Invisibleinvisible
(tick)
No decaynoDecay(error)
Skylight portallightPortal=1(error)
SimplelightPortal=2(tick)
Store with irradiance mapstoreWithIrradianceMap(error)
Affect diffuseaffectDiffuse
(tick)
Diffuse contributiondiffuse_contribution
(tick)
Affect specularaffectSpecular
(tick)
Specular contributionspecular_contribution
(tick)
Affect reflectionsaffectReflections
(tick)
Shadow biasshadowBias
(tick)
CutoffcutoffThreshold(error)
 V-Ray IES LightLightIESMax
Enabledenabled
(tick)
Enable viewport shading(minus)
Show distribution(minus)
Targeted
(tick)
Ies fileies_file
(tick)
Rotation X
(tick)
Rotation Y
(tick)
Rotation Z
(tick)
(tick)
Cast shadowsshadows
(tick)
(tick)
(tick)
(tick)
(tick)
Use light shape:
No
For shadows only
For illumination and shadows
soft_shadows=0
soft_shadows=1
soft_shadows=2
(error)
(error)
(error)
Override shapeies_light_shape(tick)
Shapeies_light_shape(tick)
Heighties_light_height
(tick)
Widthies_light_width
(tick)
Lengthies_light_length
(tick)
Diameteries_light_diameter
(tick)
Color mode:
Color
Temperature
(tick)
(tick)
Colorcolor
(tick)
Color temperaturecolor
(tick)
Override inter:
rescale
replace
override_prescribed_power=0
override_prescribed_power=1
(tick)
(tick)
Intensity type:
power (lm)
intensity (cd)
(tick)
(tick)
Intensity valuepower
(tick)
Area specularsarea_speculars
(tick)
Viewport wire color(minus)
Icon text(minus)
Exclude
(error)
(error)
 V-Ray Ambient LightLightAmbientMax
Enabledenabled
(error)
Mode:
Direct + GI
Direct light
GI
mode=0
mode=1
mode=2
(error)
(error)
(error)
GI min distancegi_min_distance
(error)
Colorcolor
(error)
Intensitycolor
(error)
Light map
(error)
Compensate exposurecompensate_exposure
(error)
Exclude...
(error)
(error)
 V-Ray SunSunLight
Enabled
  enabled
(tick)
Intensity multiplierintensity_multiplier
(tick)
Size multipliersize_multiplier
(tick)
Filter colorfilter_color
(tick)
Color mode:
filter
direct
override
color_mode=0
color_mode=1
color_mode=2
(tick)
(tick)
(tick)
Sky model:
Preetham et al.
CIE clear
CIE overcast
Hosek et al.
Improved
sky_model.0
sky_model=1
sky_model=2
sky_model=3
sky_model=4
(tick)
(tick)
(tick)
(tick)
(tick)
Ground albedoground_albedo
(tick)
Indirect horiz illuminationhoriz_illum
(tick)
Blend angleblend_angle
(tick)
Horizon offsethorizon_offset
(tick)
Turbidityturbidity
(tick)
Ozoneozone
(tick)
Exclude
(error)
(error)
Invisibleinvisible
(tick)
(tick)
Diffuse contributiondiffuse_contribution(tick)
(tick)
Specular contributionspecular_contribution(tick)
Cast atmospheric shadowsatmos_shadows(error)
(tick)
Photon emit radiusphoton_radius(error)
Physical Camera
 UINative nameV-Ray Plugin nameSupport
Max Camera
 Physical CameraCameraPhysical
Targeted
(tick)
Target Distance
target_distance
(tick)
Show Cone:
When Selected
Always
Never
(minus)
(minus)
(minus)
Show Horizon Line(minus)
Texture Resolutionbmpaperture_resolution
(error)
Use Lens Filedistortion_type=2
(error)
Lens Filelens_file
(error)
Preset(minus)
Widthfilm_width
(tick)
Focal Lengthfocal_length
(tick)
Specify FOVspecify_fov
(tick)
FOVfov
(tick)
Zoomzoom_factor
(tick)
Aperturef_number
(tick)
Use Target Distancetargeted=1
(tick)
Customtargeted=0
(tick)
Focus Distancefocus_distance
(tick)
Lens Breathing
(tick)
Enable Depth of Fielduse_dof
(tick)
Shutter Type(minus)
Durationshutter_speed
(tick)
Offsetshutter_offset
(error)
Enable Motion Bluruse_moblur
(error)
Exposure ControlSettingsColorMapping/exposure
(error)
ManualISO
(tick)
Target
(error)
Illuminantwhite_balance
(error)
Temperaturewhite_balance
(error)
Customwhite_balance
(error)
Enable Vignettingvignetting
(error)
Amountvignetting
(error)
Aperture Shape:
Circular
Bladed
blades_enable=0
blades_enable=1
(tick)
(tick)
Bladesblades_num
(tick)
Rotationblades_rotation
(tick)
Custom Texturebmpaperture_tex
(error)
Affect Exposurebmpaperture_affects_exposure
(error)
Center Bias (Ring Effect)center_bias
(error)
Optical Vignetting (Cat Eye)optical_vignetting
(error)
Anisotropy (Anamorphic Lens)anisotropy
(error)
Lens Shift:
Horizontal
Vertical
horizontal_offset
vertical_offset
(tick)
(tick)
Tilt Correction:
Horizontal
Vertical
horizontal_shift
lens_shift
(tick)
(tick)
Auto Vertical Tilt Correction
(tick)
Distortion Type:
None
Cubic
distortion=0
distortion_type=1
(error)
(error)
Amountdistortion
(error)
Texturelens_file
(error)
EnableRenderView/clipping
(tick)
Clipping NearRenderView/clipping_near
(tick)
Clipping FarRenderView/clipping_far
(tick)
Environment Near Range(minus)
Environment Far Range(minus)
V-Ray  Camera
 V-Ray Physical CameraCameraPhysical
Targeted –
(tick)
Camera Type:
Still cam
Movie cam
Video cam
type=0
type=1
type=2
(tick)
(error)
(error)
Target distancetarget_distance
(tick)
Focus distancefocus_distance
(tick)
Show cone(minus)
Show horizon line(minus)
Use Field of viewspecify_fov
(tick)
Field of viewfov
(tick)
Film gate (mm)film_width
(tick)
Focal length (mm)focal_length
(tick)
Zoom factorzoom_factor
(tick)
Film speed (ISO)ISO
(tick)
F-Numberf_number
(tick)
Shutter speedshutter_speed
(tick)
Shutter angleshutter_angle
(error)
Shutter offsetshutter_offset
(error)
Latency (s)latency
(error)
Depth of fielduse_dof
(tick)
Motion bluruse_moblur
(error)
Exposure:
No exposure
Physical exposure
Exposure value (EV)
exposure=0
exposure=1
exposure=2
(tick)
(tick)
(tick)
Exposure valueexposure_value
(tick)
(error)
White balancewhite_balance
(tick)
Custom balancewhite_balance
(tick)
Temperature (K)white_balance
(tick)
Automatic vertical tilt
(tick)
Tilt:
Vertical
Horizontal
lens_shift
horizontal_shift
(tick)
(tick)
Shift:
Vertical
Horizontal
vertical_offset
horizontal_offset
(tick)
(tick)
Guess vert tilt
(tick)
Guess horiz tilt
(tick)
Enable Bladesblades_enable
(tick)
Bladesblades_num
(tick)
(tick)
Center biascenter_bias
(error)
Anisotropyanisotropy
(error)
Optical vignettingoptical_vignetting
(error)
Bitmap aperturebmpaperture_enable
(error)
Affect exposurebmpaperture_affects_exposure
(error)
Bitmap resolutionbmpaperture_resolution
(error)
Bitmap
bmpaperture_tex
(error)
Distortion type:
Quadratic
Cubic
Lens file
Texture
distortion_type=0
distortion_type=1
distortion_type=2
distortion_type=3
(error)
(error)
(error)
(error)
Amountdistortion
(error)
Lens filelens_file
(error)
Map
distortion_tex
(error)
ClippingRenderView/clipping
(tick)
Near clipping planeRenderView/clipping_near
(tick)
Far clipping planeRenderView/clipping_far
(tick)
Near env range(minus)
Far env range(minus)
Mode:
Disabled
Top to bottom
Bottom to top
Left to right
Right to left
rolling_shutter_mode=0
rolling_shutter_mode=1
rolling_shutter_mode=2
rolling_shutter_mode=3
rolling_shutter_mode=4
(error)
(error)
(error)
(error)
(error)
Duration (s^-1)rolling_shutter_duration
(error)
Geometry
Native NameV-Ray Plugin NameSupport
V-Ray Clipper
VRayClipper
(error)
V-Ray Displacement
GeomDisplacedMesh
GeomStaticSmoothedMesh
(error)
(error)
V-Ray Fur
GeomHair
(error)
V-Ray Instancer
Instancer
(tick)
V-Ray MetaBall
(minus)
V-Ray PlaneGeomPlane
(error)
V-Ray Proxy
GeomMeshFile
(tick)
V-Ray SceneVRayScene
(error)
V-Ray Sphere
(minus)
V-Ray VolumeGrid
PhxShaderSimVol
(error)
Materials
Tabs Page
titleMaterials
V-Ray ALSurfaceBRDFALSurface
  • Diffuse
  • Diffuse strength
  • Reflect color
  • Reflect strength
  • Reflect roughness
  • Reflect IOR
  • Reflect distribution GGX
VRayBlendMtlBRDFLayered
  • Base material
VRayBumpMtl
BRDFBump
  • Base material
  • Bump map
  • Bump amount
VRayCarPaintMtl
BRDFCarPaint
  • Base color
  • Base reflection
  • Base glossiness
  • Coat color
  • Coat strength
  • Coat glossiness
VRayCarPaintMtl2BRDFCarPaint2
  • Base color
  • Base reflection
  • Base glossiness
  • Base glossiness tail
  • Coat color
  • Coat amount
  • Coat ior
  • Coat glossiness
VRayLightMtl
BRDFLight
  • Color
  • Color multiplier
  • Direct Illumination On
VRayScatterVolume
BRDFScatterVolume
  • Overall color
  • Scatter Color
VRayFastSSS2
BRDFSSS2Complex
  • IOR
  • Subsurface color
  • Specular color
  • Specular amount
  • Specular glossiness
VRayStochasticFlakesMtl
BRDFStochasticFlakes
  • Hilight glossiness
  • Reflection filter
  • BRDF Type: GGX
Two SidedMtl2Sided
  • Front Material
  • Back Material
  • Translucency
VRayToonMtl
BRDFToonMtl
Loads as BRDFVRayMtl, toon parameters are ignored.
VRayPointParticleMtl
BSDFPointParticle
Loads as a simple diffuse BRDF.
VRayMtl
Tabs Page
titleVRayMtl
UINative nameV-Ray plugin Name (plugin/parameter)Support
VRayMtlBRDFVRayMtl
Diffuse
diffuse
(tick)
Diffuse Texturediffuse
(tick)
Roughnessroughness
(error)
Roughness Textureroughness
(error)
Preset-
(tick)
Enable Bump map-
(tick)
Bump amountbump_amount
(tick)
Bump Texturebump_tex
(tick)
Reflectreflect
(tick)
Reflect Texturereflect
(tick)
Reflect Glossinessreflect_glossiness
(tick)
Reflect Glossiness Texturereflect_glossiness
(tick)
Fresnel reflectionsfresnel
(tick)
Fresnel IOR
fresnel_ior
(tick)
Fresnel IOR Lockfresnel_ior_lock
(tick)
Fresnel IOR Texturefresnel_ior
(tick)
Metalnessmetalness
(tick)
Metalness Texturemetalness
(tick)
Max depthreflect_depth
(error)
Reflect on back sideoption_reflect_on_back
(tick)
Dim distance
reflect_dim_distance
(error)
Dim fall offreflect_dim_distance_falloff
(error)
Affect channel:
Color only
Color+alpha
All Channels
reflect_affect_alpha=0
reflect_affect_alpha=1
reflect_affect_alpha=2
(error)
(error)
(error)
Refractrefract
(tick)
Refract Texturerefract
(tick)
Refract Glossinessrefract_glossiness
(error)
Refract Glossiness Texturerefract_glossiness
(error)
IORrefract_ior
(tick)
IOR Texturerefract_ior
(tick)
Abbe numberdispersion
(error)
Max depthrefract_depth
(error)
Affect shadowsrefract_affect_shadows
(tick)
Affect channel:
Color only
Color+alpha
All Channels
refract_affect_alpha=0
refract_affect_alpha=1
refract_affect_alpha=2
(error)
(error)
(error)
Thin-walledrefract_thin_walled
(error)
Translucency:
None
Volumetric
SSS
translucency=0
translucency=5
translucency=6
(error)
(error)
(error)
Fog color / Scatter raduisfog_color
(tick)
Fog color Texture / Scatter radius Texturefog_color_tex
(error)
Depth (cm) / Scale (cm)fog_mult
(tick)
Scatter colortranslucency_color
(error)
Scatter color Texturetranslucency_color
(error)
SSS amounttranslucency_amount
(error)
Self-Illuminationself_illumination
(tick)
Self-IlluminationTextureself_illumination
(tick)
GIself_illumination_gi
(tick)
MultTexCombineColor / result_multiplier
(tick)
Compensate camera exposurecompensate_camera_exposure
(error)
Coat amountcoat_amount
(tick)
Coat amount Texturecoat_amount
(tick)
Coat glossinesscoat_glossiness
(tick)
Coat glossiness Texturecoat_glossiness
(tick)
Coat IORcoat_ior
(tick)
Coat IOR Texturecoat_ior
(tick)
Coat colorcoat_color
(tick)
Coat color Texturecoat_color
(tick)
Lock coat bump to base bumpcoat_bump_lock
(tick)
Enable Coat bump-
(error)
Coat bump amountcoat_bump_amount
(error)
Coat bump Texturecoat_bump_map
(error)
Sheen colorsheen_color
(error)
Sheen color Texturessheen_color
(error)
Sheen glossinesssheen_glossiness
(error)
Sheen glossiness Texturesheen_glossiness
(error)
BRDF:
Phong
Blinn
Ward
Microfacet GTR (GGX)
brdf_type=0
brdf_type=1
brdf_type=2
brdf_type=4
(tick)
(tick)
(tick)
(tick)
Use glossiness / Use roughnessoption_use_roughness
(tick)
GTR tail falloffgtr_gamma
(tick)
GTR tail falloff Texturegtr_gamma
(error)
(error)
Anisotropy Textureanisotropy
(error)
Rotation
anisotropy_rotation
(error)
Rotation Textureanisotropy_rotation
(error)
Local axisanisotropy_axis
(error)
Map channelanisotropy_derivation
(error)
Trace reflectionsreflect_trace
(error)
Trace refractionsrefract_trace
(error)
Cutoffoption_cutoff
(error)
Env. priorityenvironment_priority
(error)
Glossy Fresneloption_glossy_fresnel
(tick)
Preserve energy:
RGB
Monochrome
option_energy_mode=0
option_energy_mode=1
(error)
(error)
Double-sidedoption_double_sided
(tick)
Use irradiance mapoption_use_irradiance_map
(error)
Fog system units scalingfog_unit_scale_on
(error)
Effect IDMtlMaterialID / material_id_number
(error)
Opacity mode:
Normal
Clip
Stochastic
opacity_mode=0
opacity_mode=1
opacity_mode=2
(error)
(tick) 1
(error)
Diffuse Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Reflect Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Reflect Glossiness Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Refract Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Refract Glossiness Texture MultiplierTexCombineColor / texture_multiplier
(error)
Opacity Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Bump Texture Multiplierbump_amount
(tick)
Displace Texture MultiplierTexCombineColor / texture_multiplier
(error)
Self -illum Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Diff. rough Texture MultiplierTexCombineColor / texture_multiplier
(error)
Fresnel IOR Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Metalness Texture Multiplier
(error)
Anisotropy Texture MultiplierTexCombineColor / texture_multiplier
(error)
An. rotation Texture MultiplierTexCombineColor / texture_multiplier
(error)
GTR falloff Texture MultiplierTexCombineColor / texture_multiplier
(error)
(tick)
Translucent Texture MultiplierTexCombineColor / texture_multiplier
(error)
Fog color Texture MultiplierTexCombineColor / texture_multiplier
(error)
Coat amount Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat gloss Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat IOR Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat color Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat bump Texture Multipliercoat_bump_amount
(error)
Sheen color Texture MultiplierTexCombineColor / texture_multiplier
(error)
Sheen gloss Texture MultiplierTexCombineColor / texture_multiplier
(error)
Environment TextureBRDFVRayMtl / environment_override
(error)
Maps
 Native NameV-Ray plugin NameSupportNote
General Maps
Advanced Wood
(error)
Bitmap
TexBitmap
(tick)
BlendedBoxMap
(error)
Camera Map Per Pixel(error)
CellularTexCellular              (tick)Not supported in bump mapping
CheckerTexChecker(tick)Not supported in bump mapping
ColorCorrectionColorCorrection(tick)Not supported in bump mapping
ColorCorrectColorCorrect(tick)Not supported in bump mapping
ColorMap
TexMaxGamma(error)
Combustion(error)
Composite
TexLayeredMax
(tick)
DentTexDent(error)
FalloffTexFalloff(tick)Not supported in bump mapping
 ForestColorTexForestColor(tick)Not supported in bump mapping
GradientTexGradient(tick)Not supported in bump mapping
Gradient Ramp
TexGradRamp
Map Output Selector(error)
MarbleTexMarbleMax      (tick)Not supported in bump mapping
MaskTexMaskMax(tick)Not supported in bump mapping
MixTexMix                   (tick)Not supported in bump mapping
 MultiTextureTexMultiX(tick)Not supported in bump mapping
MultiTitle(error)
NoiseTexNoiseMax      (tick)Not supported in bump mapping
OSL MapTexOSL(error)
OutputTexOutput       (tick)Not supported in bump mapping
Particle Age(error)
Particle MBlur(error)
Perlin Marble(error)
RGB MultiplyTexRGBMultiplyMax(tick)Not supported in bump mapping
RGB TintTexRGBTintMax(tick)Not supported in bump mapping
ShapeMap(error)
SmokeTexSmoke(tick)Not supported in bump mapping
SpeckleTexSpeckle(tick)Not supported in bump mapping
SplatTexSplat                 (tick)Not supported in bump mapping
StuccoTexStucco(tick)Not supported in bump mapping
Substance(error)
 Substance2RawBitmapBuffer(tick)
SwirlTexSwirl(tick)Not supported in bump mapping
TexMap(error)
TextureObjMask(error)
TilesTexTiles(tick)Not supported in bump mapping
Vector Displacement(error)
Vector Map(error)
 VertexColorTexUVW(error)
 WavesTexWaves(error)
V-Ray Maps
VRayBitmap (VRayHDRI)TexBitmap(tick)
VRayBump2Normal(error)
VRayColorTexAColor(tick)
VRayColor2Bump(error)
VRayCompTexTexCompMax(tick)Not supported in bump mapping
VRayCurvatureTexCurvature(error)
VRayDirtTexDirt(error)
VRayDistanceTexTexDistance(error)
VRayEdgesTexTexEdges(error)Partial'Color' parameters only
VRayFakeFresnelTex(error)
VRayGLSLTexMtlGLSL(error)
VRayHairInfoTexTexMaxHairInfo(error)
VRayHDRI(VRayBitmap)
TexBitmap(tick)
VRayICCTexICC(error)
VRayLutTexLut(error)
VRayMultiSubTexTexMulti(tick)Not supported in bump mapping
VRayNoiseTex
TexNoiseMax
VRayNormalMapTexNormalBump(tick)
VRayOCIOTexOCIO(error)
VRayOSLOutputSelectorTexOSLOutputSelector(error)
VRayOSLTexTexOSL(error)
VRayParticleTexTexParticleDiffuse(error)
 VRayPointCloudColorTexMaxPointCloudColor(error)
VRayPluginNodeTex(error)
VRayPtexTexPtex(error)
VRaySamplerInfoTex(error)
VRaySkyTexSky(tick)
VRaySoftboxTexSoftbox(error)
VRayTriplanarTexTexTriplanar(tick)Not supported in bump mapping
VRayUserColorTexUserColor(error)
VRayUserScalarTexUserScalar(error)
VRayUVWRandomizerTexUVWRandomizer(tick)Not supported in bump mapping
