Open New Sequence – Loads a new cache file or sequence of files for preview.
Timeline – Changes the current frame of the cached sequence.
Auto Load Latest–Monitors the storage for newly appearing sequence files. When enabled, the Standalone Previewer tries to load a frame for the provided mask each 200ms.
UI Text Box
type
info
The Standalone Previewer allows copying the full path to the loaded cache or just the file name by right-clicking over the cache path.
UI Text Box
type
info
The drag-and-drop option can be used to load caches in the Phoenix Standalone Previewer.
width
55%
Input
width
45%
Flip Up Axis – When enabled, flips the Y and Z axis of the cache's transformation. This is useful when the cache was created with a different up axis (for example in Maya).
