This page provides information on the Body Force component.
width55%
The Body Force produces a force toward a geometry object that can be used for giving shape to the fluid. The force is pronounced outside the body, but the inside is replaced with a mechanism that suppresses the fluid's escape.
section
UI Expand
titleUI Path: ||Phoenix FD|| > Create > Body Force
Image Added
width45%
Image AddedImage Removed
Body Force Object
Image Added
Body Object | body – Specifies the selection set used as an attractor.
Remove Object – Removes selected objects from the body force calculation.
Image RemovedImage Added
Strength | strength – Specifies the force intensity. This parameter mostly affects the points outside the body. The fluid accelerates constantly towards the body until reaching it.
