Section | |||||
Follow Path Curve
Spline | spline – Specifies the selection set for the spline object providing the path.
Remove Object – Removes selected objects from the follow path curve calculation.
Follow Speed (units/sec) | axspunits – Specifies the terminal velocity of the fluid moving along the spline. This part of the force is most pronounced inside the pipe.
