Section | |||||||||||||||
UI Options
Example: Bump vs Generic material with bump
In this example, bump maps are used for the surface of the table. Both Generic and Bump materials can control the strength of the bump map by using a multiplier. The Bump material has a higher multiplier value than the Generic bump map.
Align | |||||||||||||||||
Override Control
Can be Overridden – When enabled, the material can be overridden when you enable the Opaque override option in the Global Overrides tab of App.Man.
