  • The ZIP installation allows for setting a custom environment when starting each Houdini instance. In differencecontrast, running the regular installation multiple times overwrites the V-Ray environment variables.
  • The ZIP installation can be used to run V-Ray for Houdini and V-Ray Standalone from an arbitrary location or even a network drive. That way, multiple users can start Houdini along with V-Ray for Houdini using just a script that sets up the environment variables without the need to run local installations.
  • Upgrading a ZIP installation is a lot easier too, as you don't need to run the installer on every user's computer.
  • The ZIP installation allows for quickly switching between different V-Ray versions without reinstalling it.
Installing V-Ray from Zip
V-Ray for Houdini can be downloaded from the V-Ray | Downloads section of the Chaos website (please make sure you use your login credentials to ensure access to the download links). It's recommended that you make sure your computer meets the System Requirements for running Houdini with V-Ray before installing V-Ray.
UI Text Box
typeinfo
Under the hood, the V-Ray installation relies on the Houdini 3-rd party plugins package system. Houdini's packages are .json files that specify the location of custom modules. For more information, please refer to the documentation on the SideFX website.
The "vray_for_houdini.json" package that is used to load V-Ray when Houdini is started is placed under "$HFS/packages" (e.g. "C:\Program Files\Side Effects Software\Houdini ##.#.###\packages" for Windows) when running the installer. You may set things up differently depending on your studio pipeline.
By default, when using the installer, the location of V-Ray itself is "C:\Program Files\Chaos Group\V-Ray". Just as with the "vray_for_houdini.json", V-Ray itself can be placed anywhere on disk. As long as the "INSTALL_ROOT" variable in the json file points to a valid location, Houdini should be able to find the required modules to load V-Ray.
UI Text Box
typeinfo
Note that the EULA is accepted only for new major versions during installation from zip.
Code Block
languagejava
titleExample JSON file for loading V-Ray
	"env": [
		{ "INSTALL_ROOT" : "C:/Program Files/Chaos Group/V-Ray/Houdini 19.0.383" },
		{ "VRAY_APPSDK"     : "${INSTALL_ROOT}/appsdk" },
		{ "VRAY_OSL_PATH"   : "${INSTALL_ROOT}/appsdk/bin" },
		{ "VRAY_UI_DS_PATH" : "${INSTALL_ROOT}/ui" },
		{ "VFH_HOME"        : "${INSTALL_ROOT}/vfh_home" },
		{ "PATH" : [
			"${HFS}/bin",
			"${VRAY_APPSDK}/bin",
			"${VFH_HOME}/bin"
		{ "VFH_DSO_PATH" : {
			"houdini_python == 'python2'": "${VFH_HOME}/dso_py2",
			"houdini_python == 'python3'": "${VFH_HOME}/dso_py3"
		{ "PYTHONPATH" : [
			{ "method": "append", "houdini_python == 'python2'": "${VRAY_APPSDK}/python27" },
			{ "method": "append", "houdini_python == 'python3'": "${VRAY_APPSDK}/python37" }
		{ "VFU_PLUGINS" : "${VFH_DSO_PATH}/usd_plugins/hdVRay/plugins" },
		{ "VFH_ASSET_PATH" : "C:/Users/USER/Documents/V-Ray Material Library/assets" },
		{ "HOUDINI_DSO_PATH" : "${VFH_DSO_PATH}" },
		{ "HOUDINI_GALLERY_PATH": [
			{ "method": "append", "value": "${VFH_HOME}/gallery" }
	"path" : [
		"${VFH_HOME}"
To deploy V-Ray using the ZIP archive instead of the installer, follow these steps:
  1. Unzip the V-Ray for Houdini archive.
  2. Move it to a location of your choice (e.g. "D:\V-Ray").
  3. Place the "vray_for_houdini.json" file under "$HFS/packages".
  4. Edit the "vray_for_houdini.json" and set the "INSTALL_ROOT" variable to point to the location of the V-Ray files (e.g. "INSTALL_ROOT" : "D:/V-Ray").
  5. Start Houdini.
Linux and macOS
In Linux or macOS environment, the process is exactly the same.
