width55%50%
The Body Force produces a force toward a geometry object that can be used for giving shape to the fluid. The force is pronounced outside the body, but the inside is replaced with a mechanism that suppresses the fluid's escape.
UI Expand
titleUI Path: ||Phoenix FD|| > Create > Body Force
width45%50%
Image Modified
Body Force Object
