changes.mady.by.user Gergana Lilkova
Saved on Jul 19, 2022
Saved on Jul 21, 2022
When rendering with V-Ray Standalone, an OCIO configuration can be set with the following OCIO environment variables:
VRAY_VFB_OCIO_INPUT_COLORSPACE – Specifies default OCIO input color space.
VRAY_VFB_OCIO_DISPLAY_DEVICE – Specifies default OCIO display device.
VRAY_VFB_OCIO_VIEW_TRANSFORM – Specifies default OCIO view transform.
For example, set a default OCIO input color space, display device, and view transform:
Windows: set VRAY_VFB_OCIO_INPUT_COLORSPACE = ACES - ACEScg Windows: set VRAY_VFB_OCIO_DISPLAY_DEVICE = ACES Windows: set VRAY_VFB_OCIO_VIEW_TRANSFORM = sRGB Linux: export VRAY_VFB_OCIO_INPUT_COLORSPACE = ACES - ACEScg Linux: export VRAY_VFB_OCIO_DISPLAY_DEVICE = ACES Linux: export VRAY_VFB_OCIO_VIEW_TRANSFORM = sRGB macOS: export VRAY_VFB_OCIO_INPUT_COLORSPACE = ACES - ACEScg macOS: export VRAY_VFB_OCIO_DISPLAY_DEVICE = ACES macOS: export VRAY_VFB_OCIO_VIEW_TRANSFORM = sRGB
Note that without setting these variables, it is not possible to render in ACES color space with V-Ray Standalone.
